I am a new user of Speedup Premium from Ashampoo.
The situation is that whenever I start to install said application I face the following error message:
'the application requires the .net 2 framework'
I am then required to 'finish'
Win 7 Ult OS is functional on my computer but I don't think that Net 2 Framework is regarded in this OS. Am I right or not?
I think that being Win 7 the application will be compatible with my OS. I have also initiated to speak to Ashampoo regarding the problem but till now I am not getting any response from them. It looks like it’s out of their support scope for Ashampoo.
Can somebody guide me on how to fix this issue? I shall be greatly thankful for anyone’s help.
Error when installing Speedup Premium from Ashampoo
The .net 2 framework is a required program that has to be installed so you can use Speedup Premium, thus the appearance of the error message “the application requires the .net2 framework.” .
NET 2 FRAMEWORK is limited to these Operating Systems: Windows XP Service Pack 2, Windows 2000 Service Pack 3, Windows 98, Windows Server 2003, Windows 98 Second Edition, and Windows ME.
Apparently Windows 7, which you are using, is not supported by .NET 2 FRAMEWORK. Aside from the limited OS it supports, the following software is also required:
Windows Installer 3.0 (Windows Installer 3.1 or later is also advice); Windows Installer 2.0 or later for Windows 98 and Windows ME
Microsoft Internet Explorer 5.01 or later for installing the .NET Framework
Disk space requirement of 280MB (for x86), or 610MB (for x64)
I hope this helps.
