Error When Installing Trend Micro Titanium Maximum Security 2012
During the Installation of Trend Micro Titanium Maximum Security 2012 an error message appears "Installation Incomplete". The image below shows the screenshot of the problem.
Any assistance and suggestion would be great.
Error:
A problem prevented the installer from setting up Trend Micro Titanium Maximum Security.No changes have been made to your computer.Please restart the installer to finish installing the software or check for more solutions online.
(Error code: # 1602, 1001, 0x00e0120027)
Close
Answered By 0 points N/A #137070
Dear Helenmarmstead,
It seems your installation is being prevented from taking action. Though it says "Please restart the installer to finish installation the software" but it is not going to finish it. please check some fact before you run installation again…
1. You should not have any other Antivirus or spyware installed otherwise this sort of problem can happen.
2. Try to Run installation as Administrator to prevent access prevention otherwise your installation can be prevented.
3. Try to keep your system clean ( rid of spam, virus, Malware etc) before processing an installation.
Hope maintaining these issues you my able to solve your problem.
Thank you.
