Error when opening illustrator on CS3
20 points
Posted on - 02/09/2012
Mention that, I use Lenovo X200 Tablet PC. The operating system of my Pc is Windows 7; which is Creative Suite 3 Design Standard. In Friday, 9/23, I tried to open Illustrator and saw an error message.
The message told me to uninstall the program first and then reinstall it again. When I tried to open InDesign and Photoshop software, I saw the same error message. Before this error message all three programs running very fine.
Then restarted my computer after uninstalling CS3 and tried to reinstall CS3 again. All the shared components installed; just Illustrator, InDesign, Photoshop, Version Cue, etc. gave me the "Component install failed" error message and did not install.
Then I went through a support page and solved all the solution except ones. Rest one is based upon Windows Event Viewer error numbers.
The last time CS3 worked and when it failed on Friday I didn’t install any updates between them. I don’t what the reason behind this.
Please give me a suggestion. Thanks in advance.
