April Rosas
30 points
Posted on - 07/19/2012
If I tried to put one MSI data into Group Policy Object (GPO) on a non PDC expert Active Directory operator; however, I received the following error: "No program in the application installation file in the active directory encounter the categories".
I don't have any errors in the PDC expert Active Directory operator. It works perfectly, but when I am using Windows 2003 operator, as of now my AD operator became windows 2008 R2. If I should create a new GPO I do not have any issue on a non pdc expert operator unless I will change it at the following day. I don't think the web has a problem.
Any ideas?
Error When Putting MSI data in GPO
PDC expert Active Directory operator was serving smoothly on your Windows 2003 operating system. But when your upgraded operating system is windows 2008 R2 at that time the error message appeared. The error message "No program in the application installation file in the active directory encounter the categories" indicates that there was a problem while upgrading your operating system. While upgrading the operating system some files were not deleted. You may not be able to delete them at all. However you can take necessary steps to upgrade your PDC expert Active Directory operator compatible with the new operating system. It will be ok. Â Â Â
I hope you understand it.
