Error when starting IBM P8 Process Engine with NetBIOS
Getting "e800042c" error when starting IBM P8 Process Engine with NetBIOS disabled.
The IBM P8 Process Engine 4.5.0 server has a dependency on NetBIOS, which is documented in the IBM P8 documentation. Â How can I fix this problem? Help me.
Full error text:
Standard output: Termination of FileNet software completed.
Terminating processes…
Initializing FileNet software…
Exec of 'fn_build -a -q /fnsw/local/logs/fn_build/fn_build.log' returned non-zero status of '0xe800042c'.
Software will now be shutdown due to previous error.
Starting index database…
Shutting down security database…
Shutting down index database…
Exit value: 0
