I want to Burn an ISO image onto a DVD. While trying to do this I get an error.
Can someone help me with this issue?
I am using ImgBurn in order to burn or convert images.
Error : ImgBurn
Optimal L1 Data Zone Start LBA: None Found! (VTS_01)
This image has not been mastered correctly for burning onto a double Layer (OTP Track Path) disc.
None of the cells meet the ‘DVD-Video specification’ criteria for a potential layer break position.
Do you want to continue anyway?
Yes No
When I click on yes I got my software work again and after sometime it shows the same error message again.
If I click on NO then it shows nothing but eject my DVD.
I tried to do the project with Expression Blend. It shows another error message like Zuuuuny error.
Error: zune error
Any solution out there guys?
Please help me
Error when trying to Burn an ISO image on to a DVD.
I think maybe you are using the wrong type of disc when burning the ISO image. You should check first the disc image that you are going to burn if it should be burned on a double-layer disc or on a standard type of a DVD disc. If you have no idea on what type of CD or disc to use, try using an ordinary type of blank DVD disc when burning it. This should fix the problem.
But if you still encounter another problem when you use an ordinary DVD disc on the disc image, then the problem is really on the ISO disc image that you are using. If you downloaded the ISO disc image from a web site, try downloading another one that is already mastered to be burned to a double-layer DVD disc.
