There is an error message that says “Update DAT 6808 – Weird error message”. I get this error when I want to download McAfee update from the McAfee website. I need to know about McAfee updates. What are the options that I have when it comes to updating McAfee.
points
Error when Updating DAT 6808
Hello William W Rubin,
This problem means it is a bad update, you need to run the new version of Virtual Technician which is able to collect certain system information from your PC in order for the program & McAfee Support to diagnose & resolve any problems related to your McAfee software.
You can get it available from here, and it should be fixed your problem.
