Error when updating iOS 6 beta 3 OTA
I was trying to update my phone to IOS 6 BETA 3 Ota but the software update failed with the following error message. The error occurred downloading this software as you can see below the attached image. I need an expert’s advice so please help me with proper solution and guidance.
Thanks for everything.
Software Update Failed. An error occurred downloading iOS 6 beta 3.
Best Answer by Jackson Wilson
Answered By 0 points N/A #175886
In general when a beta releases, the servers often get loaded with lots of requests from users. So be
patient and try after sometime by restarting Wifi connection.
You can update from iTUNES:
1.   Launch iTUNES from Mac or PC.
2.   Plug-in iPHONE to system.
Go to Summery tab select iPHONE and in section choose check for updates.
Answered By 0 points N/A #175887
The best solution to fix this issue is mentioned below step by step.
1. First you have to restore data from a backup by connecting your device into iTunes
2. Now you can easily update the latest version of IOS 7.02
3. You can do this manually by keeping the phone on restore mode
Just make sure you have the latest version of iTunes then you can download the IOS 7.02 from your device.
Feel free to discuss any issue. Thanks!
Answered By 0 points N/A #175888
Hi
This is a known issue for some of the iPhone users. Don't worry it's solution is easy. There is another Techyv which is also addressed this issue. Go that page and get more info.
