J Anderson
15 points
Posted on - 10/19/2011
I was using Autodesk Revit Architecture 2012 when I got this error message (see below).
I was trying to copy a selection of drawings when the error happened. I have searched the web, but no one has yet encountered such problem so this site might provide me or help me find a solution.
Thanks in advance.
Error – cannot be ignored
Selection cannot be copied.
Multiple instances of the same view in sheets not supported.
Error when using Autodesk Revit Architecture 2012
If you were trying to copy using the copy command, you can't really copy it. Revit doesn't allow the same DWG view to be placed in more than one sheet so, when we want to move a set of views, it doesn't let us to copy, cut or paste. It gives an error.
The way to move the views is to open the sheets category in the project browser.
Then drag-drop the views to another sheet in the project browser or in the DWG area.
If you were trying to relocate the viewport, just restart Revit based from this post:
