I am getting a couple of warning messages using Kaspersky Internet Security 2012. One error says
"License: Problem detected", and another would say “Databases: Corrupted".
I am clueless with these things, and I badly need your help to remove these messages and solve the problem.
Error When Using Kaspersky Internet Security 2012
This is the only error that troubles almost all users with the free trial pack and the non-updated version of the antivirus. All that might have happened with your antivirus is that you have not installed the updates to your antivirus. Moreover the trial pack does not allow all the facilities available in your system. This is the main cause for the system in attack. You moreover mention Database corrupted. That means, some or the other virus programs might have corrupted you antivirus database. Now all that you may do is to use a bootable antivirus, scan the entire system and then you shall re-install the latest antivirus to your system.
