AClaris
Posted on - 10/19/2011
Hi Experts,
I am new to Paint Shop Pro, and I want to ask about the error message that popped on my screen.
Please see the screenshot below. You see, I was trying to save a file and I tried to search the web but didn’t get any possible and easy solution to the problem.
I hope I can turn to experts in this forum to give me a simple step by step solution on how to resolve this problem.
Thanks in advance.
Paint Shop Pro X
An undefined error has occurred – %u
ayessa
Error when using Paint Shop Pro X
Hi Aclaris,
Problem will always occurred if the application you installed was not compatible with your Operating System. Paint Shop Pro X is compatible only with Microsoft Windows. You should installed software that supports the Paint Shop Pro X application. It is only available in Microsoft Windows. Which can help you and can recommend ways in installing the Paint Shop Pro X.
Notification coming from the Microsoft Windows will appeared to help you get rid of your problems. It will instruct you step by step to help you use the Paint Shop Pro X.
Hope this will help you,
Thanks,
Ayessa
