All the time when I have finished browsing and I want to close down a window,
I receive an error prompt that reads “IExplore.EXE -Application Error message.
This is shown in below picture. How can I remove this error?
IEXPLORER.EXE – Application Error
The instruction at "0x62304390" referenced memory at "ox62304390". The memory could not be "read".
Click on OK to terminate the program
mrfarhan
Error while closing any window
Hi!
There is some Trojan virus with the name of iexplore.exe. This virus attack on every directory that you open. Because the every directory use explorer.exe file even it is internet explorer file.
Just scan your computer with registered Anti Virus program or Registry Scanner like Uniblue Registry Cleaner. And upgrade your internet explorer.
That is a virus and you will need to remove it. The iexplorer.exe itself may have found its way on your computer as a result of some software that you might have installed. The virus, spyware, or adware program that is causing the problem imitates the internet explorer browser file that has the same name, iexplorer.exe.
You will need to download a software that will help you remove that virus without affecting the browser file of your internet explorer. Visit the following site to download the application that you will need to install on your computer, and the execute it and use it to remove the virus:
https://itstillworks.com/12355881/how-to-delete-iexploreexe-virus
Regards
Thompson Locker
