Error while installing a 64bit Office 2013 Home Premium
Hi Experts,
I tried installing a 64bit Office 2013 Home Premium on my computer but encountered this error message that Office 2010 is existing already, I this that they should coexist both of them. Any ideas how to solve this?
We can’t install the 64-bit version of Office because we found the following 32-bit programs on your PC:
Microsoft Office Professional Plus 2010
Please uninstall all 32-bit Office programs, then retry installing 64-bit Office. If you want to install 32-bit Office instead, please run the 32-bit setup.
Please help.
Best Answer by Pagee Stephen
Answered By 0 points N/A #199023
Hi Joelabrame,
You might have been facing this problem because your operating system is not a 64-bit operating system. To make sure, please open Computer and click on System Properties. There you can see whether it is a 32-bit or a 64-bit operating system.
If it is a 64-bit operating system, you have to uninstall the 32-bit software if you want to install the 64-bit one. Same software of different architecture cannot co-exist. For uninstalling the previous program, got to Computer>Uninstall or Change a Program. A window will open showing you a list of software that you have installed in WIndows. From the list, select Microsoft Office Professional Plus 2010 and uninstall it. Then install Office Home Premium 2013. That will solve your problem
If you feel you need help please contact me.
Regards
Answered By 0 points N/A #199025
Hello Joelabrame,
To get rid of the setup error please follow the following steps:
1. First uninstall the Microsoft Office 2010. The previous version must be uninstalled before installing a newer version.
Please refer Kb Article
2. Perform the Microsoft Office troubleshooter, you can refer Microsoft support
3. Take the backup of the registry key HKEY_LOCAL_MACHINE, remove it. Reinstall the Microsoft Office 2013, it will be installed successfully.
These steps will solve your issue.
Answered By 0 points N/A #131192
This problem arise for conflicting with the version of the installer that you used. That means you can’t mix the 32-bit version and 64-version. To know more as well these solutions visit this Techyv post and get more information.
The problem is with installation of my Office 2013 Home Premium
