Error While Installing Microsoft FRx
I encountered Error code: -6003 while installing Microsoft FRx.
I have searched the internet for similar issues, but I didn't find any solution. Below is a screenshot of the error.
I hope there's anyone who can help me fix it.
InstallShield Wizard
Setup has experienced an error.
Please do the following:
Close any running programs
Empty your temporary folder
Check your Internet connection(Internet-based Setups)
Then try to run the Setup again.
Error code:-6003
Answered By 0 points N/A #137931
This issue is very broad and is usually fixed by just cleaning your registry or installing the software while disabling your anti-virus software. I suggest you use ccleaner for the cleaning of your registry and temporary folder
You can also disable your anti-virus software before performing an installation. Anti-virus software usually blocks installation components that it recognize as not safe. so better disable it for the moment. If you are worried about your internet activity.
Disable your network also then perform the installation.
Loida Arcel
