Error While Installing Vindictus, Error Code 40 Resolved.
I have downloaded the Vindictus easily, but while installing the same, it shows the Vindictus error code 40 as shown in the image
I have also tried to reinstall it several times but in vain. Please help with your suggestions.
Image result for Vindictus, Error code 40
Answered By 0 points N/A #295732
This error may be due to the reason that downloaded files have virus or something. Try reinstalling the game after you reboot your computer. In case the problem persists, then try deleting the temporary internet files from your system. If you are using Internet Explorer, click on “Tools” and select “Internet Options.” Then click on “Temporary Internet Files” under the “General” tab. Click on “Delete files.”
If you are using Chrome, then click on “more tools” and select “Clear browsing data.” Then click on “Clear browsing data” to perform the desired operation. Now try to install the game again. Hope this helps.
