Error while installing windows 7(code 0×80070570)
I’m stuck with the following error message when I try installing virtualbox for Windows 7.
As far as I can guess, the cause is a faulty windows 7 image file. So I re-copied and validated the md5.
Then the error disappeared.
Error:
Windows cannot install required files.The file may be corrupt or missing.Make sure all files required for installation are available and restart the installation.Error code:0x80070570
