Jean Moore
10 points
Posted on - 07/14/2012
Sugarcrm v.6.4.4
Php 5.2.10
While I am operating as an administrator and click the module calendar in order to make an event everything is OK but when a normal user tries to do the exact same thing an error box saying
Error while loading appears then it just closes the window.
Do you know how I can solve this?
Error while loading the Calendar
Dear,
That error normally means the calendar had trouble loading a JavaSript library it depends on. This is most often caused by a conflict with another plugin on your blog. Please try disabling any other plugin with sliders of sliding controls and see if that resolves the issue.
Thank you.
Hi there user:
Error of data while loading, that’s it. This occurs when calendar is loading too much. You may be having a slow internet connection, or one or more applications made your internet connection slower. Fix it my using the recent/latest version which is 1.21.3
Thank you for visiting us here at techv.com. You can post all your questions, and we’ll do best to help you.
Kind regards,
