Error while opening Pivot Table saved in XML Format
50 points
Posted on - 02/28/2013
I have created a pivot table and saved it in an excel file in xml file format. It creates problems when I open it again giving me an error message like the one- "This pivot table report is not valid". It works again when I refresh those data of the pivot table opening the xml file. Is there any solution of this so that I can open the xml file and make it work without refreshing those data of the pivot table?
