Hello experts,
An error while opening xlsm files on iPad 2. The .xlsm file is not allowed to be open in my iPad 2 but I need to open this file immediately. I hope that there is some way that will help me to access a .xlsm file in my iPad 2, I know you can help me guys. Thanks.
An error while opening xlsm files on iPad2.
Hi Brenda,Â
You can open XML enabled MS XLS workbook when you have MS Office or anything else can open that type of file. You can install NeoOffice for iOS (available from iOS 4 or higher) which can do the necessary works for you.
Hello Brenda,Â
Most of the IOS users are facing similar problem as yours. There is certain software in the Apple Store which you can download. This software can import the .xlsm files without any problems. For your clear understanding I'm pasting a link here. https://support.apple.com/
Thakash Kumar J
