Error while operating on Avid DS
Hello everyone,
It seems to me that I’ve made a mistake while operating with Avid DS and I am no longer able to take any actions without the following message poping-out:
“Avid DS
This request is not supported.”
I’m new at this and I’ll appreciate your help very much.  Thanks very much.
Answered By 75 points N/A #98782
Hello Miss Shanon,
Which actions exactly are you trying to carry out using the Avid media application? Because you may be trying to use it in carrying out functions that it does not support hence getting that error.
You can try restarting the avid media, close it completely from the task manager and then start it again or even restart the system and see if the problem will be resolved. If it persists then I will suggest that you uninstall it and then reinstall it again, because the error may be with the registry files, may be they are corrupted.
Hope this helps.
__
Regards
Lee Hung
Answered By 590495 points N/A #328406
If you keep receiving this error on the program, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select the affected program among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and click to delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install the program back. If this doesn’t work, check the system requirements again and verify that your computer meets those requirements. Also, if you are using a trial, check and verify that the trial period is not expired.
In case it is expired, either uninstall the program or buy it or buy a license.
