Error while running autodesk 3ds max design after successful installation
Hi all,
I have recently installed the Autodesk 3ds Max Design for animation and rendering. It was installed successfully, but when I try to run the application I get an error which reads as:
The procedure entry point
?getAppHInst@ResourceManager@@QEAAPEAUHINSTANCE_@@ XZ
could not be located in the dynamic link library splash.dll.
The screenshot of the error is as follows:
If I click OK for 3 times, then the message disappears and the software runs smoothly, but please help me in getting rid of this message.
Why does it appear every time? Your suggestions and views are awaited.
Thanks a lot.
Kind regards.
