I installed splinter cell conviction and when I tried to run the game, I encountered an error.
The error was Splinter cell conviction Ubisoft game launcher error code 2. Please help, Thanks.
Error While Running Splinter Cell, Splinter Cell Conviction Ubisoft Game Launcher Error Code 2, Help Is Needed.
Hi, First of all, this error is related to the Ubisoft launcher so firstly you should try to remove the Ubisoft game launcher from the file directory or you can un-install it, then you should re-install it.
You can install it from the DVD which you have or you can refer the below link for the game launcher.
If the above-mentioned methods don’t work you can try to do a complete cleanup of the Game launcher files and then a fresh install.
http://ubisoft-game-launcher.updatestar.com/en
I hope this will help you out.
Thanks
