Error while start FanSpdReg exe
Greetings everyone!
With RWEverything open, I got this error whenever I start FanSpdReg.exe.
Greetings everyone!
Hello Ramon
It seems to be a compatibility issue here. That is what I am guessing. And that is why that error, those codes appear.
Have you tried Uninstalling RWEverything from your PC and reinstall it? Or, you should try upgrading to the latest version. Several issues have been fixed, and this might actually solve your problem.
I will provide you with a link, from where you can download the latest RWEverything version.
Also be sure that you download the software for the OS version that you are using (32/64 bit) .
RWEverything here is the link in order for you to download.
I hope you found this information useful.
Randolph
