Error while starting up an OpenCL studio:
I got the following error while starting up an OpenCL studio:
Hardware capability not available
GL_ARB_multisample
GL_ARB_multisample
I can’t seem to find the system requirements for OpenCL Studio in the internet but based on the information I found, it directly points to the video card of the computer. It is just like the OpenGL component that is usually supported by most modern video cards. I think the error you receive when opening OpenCL Studio clearly states that the current video card installed on your CPU does not support OpenCL function. That’s what was meant by “hardware capability not available”, there is no capable hardware found on your computer that can support the required function.
OpenCL Studio, as what was posted in their website, works perfectly well with the latest NVIDIA drivers. So, to use OpenCL Studio, you need to replace your graphics card with an NVIDIA video card or with any brand that fully supports OpenCL.
