Error while taking backup in OS level
Hi
When i try to take backup in Operating system Level (redhat) it gives error "no space" while the space left ( in vmware) is 20 Gb.
Please help me with this.
Hi
Try checking the settings of your backup software. The backup parameters might be pointing to a destination that is not allowed by the operating system. Change the destination to a new location that is not being used by the system.
You may also try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit or Norton SystemWorks. Any errors in the file system can cause problems to applications. It can also make installations to go wrong that leads to an incomplete product installation.
