Error while tried to run the eclipse model acceleo M2T transformation
Hello all
Recently when I tried to run the eclipse model acceleo M2T transformation, I was met with an error related to the coherence between the ecore metamodel and the xmi model. The error reads as:
org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'System' is not found or is abstract. (model.xmi)
When manually registering the metamodel and validating the model there were no problems.
At first I was having much more problems as you can see in the screenshot below which was solved by adding missing libraries. Now only the above problem is shown, but some of this problems may persist.
Please send in your suggestions. I'll be obliged.
Kind regards
