Error while trying to convert the Audio format to AC3 or MP3
Hi all,
I have tried to rip a DVD to HDD as well as withAutoMKV. I have tried to convert it to XVid. I have also tried to convert the Audio format to AC3 or MP3, but all the time, I find the following message:
Encoding Audio with After- first normalizing volume wait", and nothing occurs.
Here is a log:
Code:
00:29:41 0.98.4 – – – – – – – – – – – – – START JOBS – – – – – – – – – – – – – –
00:29:41 Selected Input file: D:VideosMyMovie_S06DISC1VIDEO_TSVTS_01_0.IFO
00:29:41 Selected Output dir: D:Videostemp
00:29:41 Selected Final Name: MyMovie_S06DISC1
00:29:41 Selected Container type: AVI
00:29:41 Selected Encoder: XviD
00:29:41 Selected Size: 1500 / 1
00:29:41 Selected Profile: 2_Pass_Extreme_Quality.xml
00:29:41 Selected Resizer: NONE / Original
00:29:41 Selected Filters: RemoveGrain(mode=2)
00:29:41 Selected Deinterlacer: AUTO
00:29:41 Selected Field Order: AUTO
00:29:41 NeroAACEnc.exe: not present
00:29:41 Activate PGC Ripping: 1
00:29:41 Using Matrix: Sharktooth's EQM v3LR.cqm
00:29:41 Working by Command Line: queue1.ini
00:29:41 Track Language 1: 81: Deutsch (AC3 2ch, 0xBD 0x81) [0,1,2,4,5]
00:29:41 Audio Codec 1: AC3
00:29:41 Audio Quality 1: 224
00:29:41 Audio Channel 1: Stereo
00:29:41 Track Language 2: 80: English (AC3 2ch, 0xBD 0x80) [0,1,2,4,5]
00:29:41 Audio Codec 2: AC3
00:29:41 Audio Quality 2: 224
00:29:41 Audio Channel 2: Stereo
00:29:41 Advanced Audio Settings DUMP Track 1
00:29:41 Nero Option Profiles: AUTO — Encoding Mode: Quality
00:29:41 CCT Option Profiles: AUTO — Channel Options: AUTO
00:29:41 Lame Settings: ABR
00:29:41 Audio Normalization: 1
00:29:41 Frequency: AUTO — Tempo: NONE — Pitch: NONE — Other Add:
00:29:41 Advanced Audio Settings DUMP Track 2
00:29:41 Selected 1' Sub tracks: Deutsch 1 (0xBD 0x21) [0,2,4,5]
00:29:41 Selected 2' Sub tracks: English 0 (0xBD 0x20) [0,1,2,4,5]
00:29:41
00:29:41 Starting SubRipping
00:30:04 para.lst file:
00:30:04 D:VideosMyMovie_S06DISC1VIDEO_TSVTS_01_0.IFO
00:30:04 D:VideostempVTS
00:30:04 1
00:30:04 1
00:30:04 1 0 cc
00:30:04 CLOSE
00:30:04 Subtitle Size: 5146624 bytes
00:30:04 Finished SubRipping
00:30:04 Activate PGC processing: PGC 1 [1:03:39:06]
00:30:04 D:ProgrammeAutoMKVexeVsrippgcdemux.exe -pgc 1 -nocellt -nolog -noaud -nosub -nom2v -vob "D:VideosMyMovie_S06DISC1VIDEO_TSVTS_01_0.IFO" "D:Videostemp"
00:31:15 Dgindex CMD: D:ProgrammeAutoMKVexedgindexdgindex.exe -FO=0 -OM=1 -TN=81,80 -YR=2 -AIF=[D:VideostempVTS_01_1.VOB] -OF=[D:Videostempmovie] -exit -minimize
00:31:37 D2V file size: 445447 bytes
00:31:37 Audio 2: movie t80 2_0ch 192kbps delay 0ms.ac3
00:31:37 Pre Audio 2' Size: 91660800 bytes
00:31:37 Audio 1: movie t81 2_0ch 192kbps delay 0ms.ac3
00:31:37 Pre Audio 1' Size: 91660800 bytes
00:31:39 Applying DelayAudio of 0 to audio file: movie t81 2_0ch 192kbps delay 0ms.ac3
00:31:39 Encoding D:Videostempmovie t81 2_0ch 192kbps delay 0ms.ac3 to AC3 with 224 quality.
Also, by using Process Explorer, I realized thatVirtualDubModis really hanging.
Also, it is clearly used when one more tool like FFMpeg is chosen for demuxing.
What is the actual problem?
I need a solution. Please help.
