Error while trying to generate the image in JPgraph.
I’m facing this error while trying to generate the image in JPgraph.
Is there anyone familiar with this kind of error?
I attached the error image below.
I couldn’t find any references in the net.
Please help me.
JpGraph Error
We are sorry, but the system could not generate the requested image. Please contact site support to resolve
this problem. Problem no: #25121
Thank you for your time.
Answered By 0 points N/A #145280
The problem seems to be internal to the software you are using.
1.       However sometimes the format of the image you are using matters.
2.       First know the file types supported by it.
3.       then make the size of the images compatible with it.
4.       This will create good result set.
5.       Once done the scenario lies with fixing the data and the device system through the manager programs.
6.       The later systems make it optimum and OK for the dwelling and usage of the current systems. The forum of the site may be contacted if the solutions fail. there may be a bug in the software.
