I am trying to install a replace and find software named k-free, but IÂ find the following error message:
"This program cannot be installed on Windows NT version 6.0"
I have attempted 2 dissimilar find and replace software courses. These allow me to get a pre-made website as well as replace my PayPal information and Adsense ID. I am using Vista Ultimate.
I need to solve this. Please help.
Error while trying to install a software named k-free
hello there buddy.. upon reviewing your question i found out that the reason of your problem is program compatibility. as far as we are concern we already know that vista has a lot of program compatibility issues. i download and install your program in my xp service pack 3 Operating System and it works fine. so your only option is to downgrade or upgrade your Operating System.
​Hello Chet,
As you have mentioned you are facing problem while installing K-free. It seems like a compatibility issue. As far as I know k-free software does not support windows 7 or windows vista. You can try to install it on NT 5.1 or 5.2. K-free is compatible with windows XP versions and Sp1, Sp2, Sp3. All you need to do is place k-free in the computer then go to the compatibility tab click on the option “Run this program in compatibility mode for" and after that chose an older version of windows from the menu. Thank you.
