Hi experts,
Many of these wire errors occurred while trying to use Kinesthesia vi's in an FRC CRIO project. It happened so due to Kinect library. From DLL Microsoft Kinect, this ware contains functions, properties and method. A screenshot regarding the problem mentioned above is given below.
Context Help
Data type of wire
get_Item Microsoft.Kinect.KinectSencor, Microsoft.Kinect
I think the library is working properly for the specified to the FRC framework. Can I change the property of Kinesthesia?
Please help me in this issue.
Thanks a lot.
Error while trying to use Kinesthesia vi’s in an FRC cRIO project
I’m not sure how did you get this error. If this is the first time that this happens, try restarting your computer then try it again. Restart whatever you are doing after rebooting the system. If the problem occurred after doing a program installation, try doing a clean installation of the software again to fix any corrupted files that the previous installation encountered.
Uninstall the software then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use a disk utility application like Norton Utilities. Install the product again then see if this fixes the problem. If this problem resulted from a previous upgrade then try restoring it to its previous version if it’s still possible.
