Hello everyone,
While trying to write a DVD using Nero 7 and HP DVD writer, I am flushed with the following error (see below image):
Nero Express.
Burn process failed at 8x (11,080 KB/s)
I don't know what is the problem here. How can I’ll be able to solve it?
Thanks in advance for the suggestion.
Error while trying to write in DVD using Nero.
There could be two possibilities for this error to appear. First, The CD which you are trying to burn is corrupted or may be having bad sectors in it. Second thing is that your Nero Software may be corrupted (This is a rare case scenario) but could be sometimes occur. Make sure you buy an good company CD rather buying any cheap  quality cd's. And also try to update your Nero software properly and also make sure to install or update the software properly. If you follow the above mentioned steps you cannot see such kind of error messages again.
If this type of errors is occurring frequently then there might be problem in your hardware which means there is a lens inside your DVD drive which might not be able to work properly. so, for this you to consult with your service provider or there might be the DVD that you have bought for burning process. Or you can lower your burning speed it might work .Â
Thank you
