Error while upgrading Windows 7 with CD
Posted on - 06/05/2013
I was trying to run the Windows 7 upgrade CD but it showed me the error message “The installation disc isn’t compatible with your version of Windows”. I can’t understand what is happening with my system so I need your help in this case to solve this matter.
Windows Setup
This installation disc is not compatible with your version of Windows. To upgrade, you need the correct installation disc. For more information, check your computer’s system information. To install a new copy Of Windows, restart (boot) your computer using the installation disc, and the select Custom (advanced).
