Error – Win 32 only: Combofix shows error message.
Every time I tried to open ComboFix on my computer it shows me an error message.
What should I do to solve this problem?
I use windows XP.
Error – Win32 only
Incompatible OS. Combofix only works for workstations with windows 2000 and XP
OS incompatible. Combofix ne fonctionne que pour Windows 2000 et XP
OS not compatible. Combofix kan enkel gebrukt worden voor Windows 200 und XP
Kayttojarjestelma ei ole yhteensopiva. ComboFix toimi vain Windows 2000 – ja XP – Kayttojarjestelmissa
Incompatible Combofix. Apnar comboFix shudhumatro Windows 2000 en XP te cholbe
SO. Incompatible. comboFix funciona unicamenete en windows 2000 y XP
