Error on a Word press blog showing missing homepage
I have a blog on WordPress.com, but now when I go to my main page, I get an error:
"Apologies, but the page you requested could not be found.
Perhaps searching will help."
I was thinking that editing the main page would fix this, but I can’t even find that page on my dashboard now.
So how can I fix it?
Any help please?
Answered By 5 points N/A #100584
 Dear Emmon,
Please find the below mentioned following methods to resolve the issue.
Method 1: Post a New blog. In order to achieve this navigate to Post > Add New and then publish a new blog entry. Once that is complete the new page will be replacing the home page of your blog and hence the message will vanish.
Method 2: Utilization of a static front page instead of a dynamic one can be a fix to the issue. Hence your blog settings can be adjusted to yield static front page.
Method 3:  Go to Permalink settings and select default instead of Custom to fix the issue.
