Error working with Adobe Acrobat Pro 9
        Please take a look the following error message that I am getting working in Adobe Acrobat.
Adobe Acrobat
The document has been saved, however, it could not be converted according to the select standard profile: convert to PDF/A. please use prefight with the profile “Convert to PDA/A” in order to identify those properties of the document which prevent it from being compliant to this profile.
