Chaya Dixon
Posted on - 02/02/2012
Hello
In DVD drive I play a DVD which has video and mp3 data. Using SmartRipper software I want to rip the video files.
After that I find the following error:
Smart Ripper
Some files still locked !
Try to unlock with a player.
Please help me to solve it.
Thanks a lot.
Error writing DVD using SmartRipper
Did You launch already the SmartRipper with your movie in the hard drive?
And If the some files need to be unlocked with a software plater then kindly do it. Then Select files on the button of Smart Ripper and it will select automatically only the .vob files just only for the main movie.
It probably look like VTS_02_3, VTS_02_1, VTS_02_2 And etc. It should be all 1 GB except the last one, which is almost always be the smallest. You can only need to select one more file, which will be the IFO file, and it will have the same number as the VOB files that SmartRipper selected automatically.
Based on the example that I put, this file would look like this: VTS_03_0 and be marked as IFO. Create the directory to rip the files to and click start. And then start the program, after that select the directory in which you will ripped the movie. And then select the destination directory and hit the next button. Only one title should show up in the next screen, select the title showed and hit next again. Check the boxes you want for audio and subtitles and then hit Start. It is advisable not use any other software during this process. And the compression will be finished after 15-60 minutes.
I hope this helps.
