Error. wscript.exe Access is Denied.
I happen to have win server 2003. I think it's because of some spyware, wscript.exe is blocked.
When I try to run an .VBS file I get error Access Denied.
I'm using the administrator account.
Hey Maggie Holmes!
Here is a solution for you. What you need to do is just to follow these steps.
1. Click on start button. Select Run and type regedit.
2. It will open registry editor. Now go to the following path by expanding the (+) sign.
My ComputerHKEY_CLASSES_ROOT*Shell
3. Here you have make a new key under Shell with name shortpath.
4. Now click on that new key. On the right side you can see Default named value, right click on it and edit it.
5. You have to right "Get Short Path for this".
6. After this you have to make a sub-key with name "Command" under shortpath.
7. Here again on the right side you can see Default. Edit it by pressing right click on it.
8. In the Value Data, type D:Utilsmyscriptslongtoshort.vbs" "%1 (You have to change the path according your installation).
Close the registry and you are done.
Thanks
Hi ,
If you are having a problem opening VBS file you should follow the following.
1) Identify the program that can be able to open the file
2) Check your personal computer for invalid registry and other speed issues
The following are the detailed information about VBS
Primary association: MPEG MOVIE SCRIPT
Mime type :Â VIDEO/MPEG
NOTE
Invalid could be due to the underlying issue in your personal computer. Please scan it for
a) Invalid entries
b) Unused processes
c) Other slow down issuesÂ
You may also download the following vbsfix.zip. Save in the desktop. Unzip the archive folder and store the file in this folder.
When you are using windows XP click vbsfix_xp.reg to run it
When using Windows Vista click vbsfix_vista.reg to run it
Click yes for confirmation
These are the ways that you may be able to close that open port that is bugging you
