Whenever I am trying to install the driver cd package given with my recently bought ASUS motherboard, I get the following error message.
“Error:5 – Cannot execute D:BinInstAllItemDriverAsusSetup.exe –a”
I can’t understand why this is happening. Please help ASAP.
Hi Helenmarmstead,
This problem can happen for some reasons, which are listed below:
OS bit (32 or 64) are not compatible
File missing
File corruption
Drive fail to read the file
If the first problem happens then you have to use the compatibility mode. To do that you have to copy whole DVD to your HDD then right click on the setup exe file and click to the properties then go to the compatibility mode tab and select the suitable one. Then try again.
Hope you will get better result. Good luck.
