ERROR_INSTALL_PACKAGE_VERSION 1613 This installation package cannot be installed
ERROR_INSTALL_PACKAGE_VERSION 1613 This installation package cannot be installed by the Windows Installer service. You must install a Windows service pack that contains a newer version of the Windows Installer service.
I have a problem installing applications built by Installer Shield Express. The error message says "The installation package cannot be installed by the Windows Installer service. You must install a Windows service pack that contains a newer version of the Windows Installer service." Running InstMsiA.exe before running installation would make it work.
Is it possible to include the execution of InstMsiA.exe at the start of the installation to prevent problems from happening?
