Errors with Adobe Flash Player 10
Hi all,
I did a few things in one site and it suddenly generated errors with my Adobe Flash Player 10.
How do I, if possible, undo things?
Need your ideas.
Hi all,
Need your ideas.
Dear user,
When you are getting this problem, a simple uninstallation wouldn’t fix your problem. Here is the solution that has worked for me.
Download this tool from the link below and uninstall your old version of Flash player. And re install it.
http://kb2.adobe.com/cps/141/tn_14157.html
This will possibly fix your problem.
Thank you
Dear if you want to undo this.Â
Click Start Button Go to All programs.
Then Choose "Accessories" and then "System Tools" In System Tools Select "System Restore"
System Restore Window Will Open.
On this window there will be two Radio Buttons
1. Restore My Computer to an Earlier Time
2. Create a Restore Point
You Have to choose 1 Radio button and then click  "Next"
Here on the left side there is a calendar given.
Some Dates on this calendar will BOLD WRITTEN. Choose Previous Bold Date from the calender. Or that date on which you have updated some files or Previous that.
After Selecting the Date. Click Restore button. Your Computer Will restore some settings and then Reboot.Â
Your problem will be 100% Solved on Reboot
Thanks
Hello Anonymous,
There is a another Techyv post which one will be helpful for you too to get more information about  the error  of Adobe Flash Playe 10. Visit this site and get more idea.
Error when using Adobe Flash Player
