Errors after installing Corel VideoStudio Pro X4 Full Version
I had the trial version of Corel VideoStudio Pro X4 installed on my computer and later I bought and installed the full version. I had a problem after installing SP1 and the application stopped working. I had to restart it and hence lost all the unsaved data. So I uninstalled the trial version and reinstalled the application from the disc. It worked fine but later on, I had a problem with the security program. So I did a system restore but now I am unable to access the program and receive the error “Error 4: Corel VideoStudio files have been damaged or modified. Please reinstall your original source. “But when trying to reinstall the program, the error “Setup.xml could not be loaded. This may indicate that the file is corrupt.” occurs. I get the same error message on trying to uninstall it. How can I get this corrected? Please help.
