Errors in angry birds Brazil download
Hi there everyone!
I have issue encountered. It’s about my angry birds Brazil download. I’ve been encountering errors installing it on my PC. Is there any ways to correct this error? Thanks in advance.
Answered By 0 points N/A #137062
Hi Sharipcheney,
Just relax! Many user now a days having the same problem. It’d be better if you described your PC configuration, though I think you are using a standard PC. Here are some steps you may follow:
1. You’ve already downloaded Angry Birds Rio. Install it but do not run the software first, you need to do another procedure.
2. It’d be better if you first run the patch (. exe) file from the patch folder.
3. Now click on the Patches and select the file which you already installed (usually it’d be in the program files).
4. You can run the game now and may be asked for serial no. Input the serial.
Now you are ready to play the game.
Good Luck.
