Is there anyone who would like to help me fix this problem on how to connect my Samsung GT-C3010 through my desktop for searching web on my computer from the Aircel GPRS which has a Bluetooth dongle in Windows XP Service Pack 2?
As I link up my mobile phone to desktop, I noticed error code 777 and 692.
How to resolve this?
Thanks for the help.
Errors on connecting Samsung phone to my PC
For that you will need to make sure that your computer is Bluetooth enabled and the mobile phone too, so that you will be able to connect to internet on the laptop via the phone through Bluetooth or dial up connection.
Once you have established that the two devices are Bluetooth enabled:
You will need to turn the Bluetooth on both devices on.
And then use the computer to search for the Bluetooth devices in range, it will for sure find the mobile phone and then you will add it.
Once you have the mobile phone added to your computers Bluetooth devices, you will need to go to wireless network properties.
There you will locate the mobile phone device and right click on it.
You will then choose connect via access point
Your computer will be connected to the internet.
Mathew Stone
