Errors in installation of Office 2010
Hello Everyone,
I am using Windows 7 64 bit and I recently want to install Office 2010 student. There are some error messages appearing whenever I am trying to install Office 2010. The first error comes as “Error 1935 during installation of assembly component (63E949F6-03BC-5C40-A01F-C8B3B9A1E18E). HRESULT: 0x800736FD.” While the second error that does appear “You do not have permission to execute the program / update, contact your system administrator.” Please note that I am using the only single profile in my computer and I am the only administrator. Can somebody help me fix these errors in installation? I would greatly appreciate your response.
Thank you in Advance
Best Answer by Ratyr patsr
Answered By 0 points N/A #131194
Installation of office 2010 creating problems.
You have an administrator account.
1. You had installed office before this installation and it created problems when installing.
2. Try to use a genuine version of the software.
3. Open command prompt and them type regedit. exe, and you will see a window .Delete all registry settings of office. Delete all occurrence of Microsoft office from the registry.
Your installation should continue now without errors. If it still exists, then on your system drive check properties and security tab. Give full control to Administrator account and then reinstall the above software. This should surely work. Let me know it not solved.
Answered By points N/A #131195
You are having this error for logged in on your PC utilizing a non-administrative account generated via your Network administrator.
To know more causes of occurring problems and solution also will be helpful for you another Techyv link which is “ERROR 1935 while installing Microsoft office 2010 on Windows 7”.
Visit this site and get more info about your problem.
