Errors occurred when building Abiword using visual studio 2010.
I am trying to build Abiword using visual studio 2010. But a very number of errors occurred. Can anyone solve this for me.
Thank you.
Thank you.
Hello Pedro,
There can be a lot of errors when you are building with missing dependencies, wrong folders etc. I have found for you a step by step how to build Abiword document that you can consult to build Abiword successfully. It mentions all preparation you need to do and what dependencies it has. You can find this Abiword Build Guide at the following link: https://www.abisource.com/~fjf/BUILD.phtml
Make sure that you follow all the steps for Windows and you will be good to go, without any errors. If for some reason an error appears, make sure you post it also so we know what we are fixing.
P Vhilary
