I recently downloaded the update for S/MIME for Outlook Web Access and now I am unable to copy and paste text to a message. Though I do not have the issues pasting text in certain browsers and the hyperlinks cannot be inserted as well. Can this be resolve?
Errors on Outlook Web Access after updating S/MIME
Those are problems probably caused by the updates that you made to for the S/MIME and they could be because the updated package is not supported by the version of outlook express that you are using, and therefore you might need to retract the changes and the updates that you made.
It may also be possible that the S/MIME needs to be configured once again after you installed the new updates since the settings might have been lost during the update. Therefore reconfigure the S/MIME settings and if there are any settings that are related to the service then you will need to reconfigure them too.
Regards
Thompson Locker
