Errors when importing projects into Eclipse
I used CMAKE-GUI and MinGW under Eclipse CDT to build vlmc under windows. So, I configured CMAKE to generate Eclipse project files. I then imported the projects into Eclipse and proceeded to build it. However, it suddenly stops and shows me some errors. The referenced directories and files exist. So, what should I do to resolve this? Your help would mean so much to me. You can see the errors below:
[ 3%] Generating icon.o
cd C:UsersAdminDocumentsGitvlmc-2.0-eclipsesrc && -IC:UsersAdminDocumentsGitvlmc-2.0-eclipse -iC:/Users/Admin/Documents/Git/vlmc-2.0-eclipse/cmake/icon.rc -o C:/Users/Admin/Documents/Git/vlmc-2.0-eclipse/src/icon.o
mingw32-make[2]: Leaving directory `C:/Users/Admin/Documents/Git/vlmc-2.0-eclipse'
mingw32-make[1]: Leaving directory `C:/Users/Admin/Documents/Git/vlmc-2.0-eclipse'
The filename, directory name, or volume label syntax is incorrect.
mingw32-make[2]: *** [src/icon.o] Error 1
mingw32-make[1]: *** [src/CMakeFiles/vlmc.dir/all] Error 2
mingw32-make: *** [all] Error 2
