Errors when trying to install software from CD.
I encountered a similar problem upon installing the two softwares on CD. First. I tried to install a phone software with Activesync. I received an error which says “Your version of DLA can read files on this disk but you will not be able to add them. ”
And the other one was "Warning", The local language and default (WWE) configuration XML file can not be found or invalid, please contact the disk manufacturer. Then, a yellow triangle appears stating "Microsoft Activesync" Error. Invalid Drive: F: Please Select a valid drive”.
Then with the installation of the second software, Turbo Tax – I get this error: A red X, an Invalid Drive, and Error code 1327. Could someone please explain to me this occurrence? What should I do to fix this? Thank you.
