Dominic A
Posted on - 10/23/2011
Hi Experts,
I was using Adobe Illustrator when I got this error message.Â
The filter that I was using seemed to be the problem, but I needed that filter.Â
I have searched the web but couldn’t find anything about the resolving filters issue.Â
Is there a workaround?Â
Please help me.
Ai
The filter cannot complete because of an unknown error.
Jackman
Error when using filter in Adobe Illustrator
If I may start by asking, do you have a valid copy of Adobe illustrator cs? To be able to run filters in your system you should install the version 11. Using valid copies of any software can help you avoid unnecessary errors while working with the software. Ensure that the illustrator is open when you open the filters so that it will use it without ensuring this could cause an error in your system. Note that the filter does not support formats in that if you put formats like bold or font changing it will not reflect this changes. Try also regrouping all the files that are using the Adobe illustrator together this will help you avoid overloading the filters by repeating the operation severally and thus avoid errors.Try all this suggestions and I hope it will work well without causing trouble anymore.
trace
