Hi there,
I have this error when I want to install Team Speak 3 on my laptop and I downloaded the version compatible with Windows 7. I tried to download it from different servers and the same problem is everywhere. Please help me to solve this! Why I have this error? Is something wrong with the software or with my laptop?
Thanks!
ts3client_win64.exe – Bad Image
C:Windowssystem32HID.DLL is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
OK
Errro occur when I installed Team Speak 3 on my laptop
There is actually no problem running TeamSpeak 3 on Microsoft Windows 7. This application supports until Windows 7. To make sure you are using the correct version, download it again from TeamSpeak 3 Client and Server Downloads. Before downloading, make sure you know your operating system’s architecture because I suspect you downloaded the incorrect version for your operating system.
I’m referring to x86 [32-bit] and x64 [64-bit]. Most x86 applications run on x64 Microsoft Windows because the operating system runs the program under 32-bit compatibility mode. But on the other hand, you cannot run an x64 application on an x86 operating system and that’s the difference. So make sure you know if your operating system is an x86 Windows 7 or an x64 Windows 7.
Download the correct version of the TeamSpeak 3 client according to your operating system architecture since the client provides different versions. For Windows, the client supports Windows 2000, Windows 2003, Windows 2008, Windows XP, Windows Vista, and Windows 7. You need an internet connection to use it. For Mac users, it supports Mac OS X 10.4 Tiger and higher. It also supports Linux.
